Hello can anybody help I have a 2001 Rangey it shuts down after about 10-15minutes then will not restart until it cools down.
I did have an issue with the air flow sensor but that has been replaced. :?
Could be related to something like the engine, fuel and/or air intake temperature sensor.
I suggest a session on T4 to find out exactly what.
That could be something simple like the fuel relay.
With those symptoms it would be the first thing i looked at.
I'd run it again with the bonnet open & when it cuts out check the temperature of the relays, if this is the cause they will be to hot to touch.
I had a similar issue with my '01 P38. On my way to work my P38 died. I pushed it to the side of the road and called the mechanic I normally go to for issues. I explained what it did and his first comment was the CKP (crankshaft) sensor. After we got off the phone I was able to start the truck and I drove it the rest of the way to work. It died as I was pulling into the parking lot at work. I asked the mechanic to order me the CKP sensor. He did, and I came to the parking lot at my work and installed it with my father-in-law. Took me about an hour, maybe a little more.
My "check engine" light did not come on for the problem so if your's isn't on I'd get a second opinion, but the CKP sensor would be my first guess. It costs about 100 USD. If you're going to have an issue it's not a bad one to have.
Hope this helps.
The fuel pump relay gets hot and overheats the fusebox PCB. You could try wiggling it around the next time it stops. See RL12.
