1 - 10 of 10 Posts
ECU needs attention. Can anyone recommend where to send the unit for repair? Currently located in northern California. Thank you.
If you are talking about Engine Control Unit (ECU), the computer that controls engine, it can not be simply swapped. The BeCM (body computer that controls central lock, power windows and a bunch of other stuff) has to be programmed to send the correct "mobilization code" to the ECU. The programming can be easily done using Rover-specific tools. Swapping a used replacement unit won't work (truck won't start), unless the programming to pair ECU and BeCM is done.
Swapping BeCM opens another can of worms, because BeCM is matched with the Remotes/Key Fobs. The easiest way is to swap a used ECU and have someone with rover-specific gear do the requisite programming. Otherwise you are swapping ECU, Instrument Cluster, BeCM and lock set. Which is not a lot of work, but will set you back something to the tune of $300. The problem with swapping the whole caboodle is that VIN programmed into the BeCM no longer matches the truck, which creates problem when ordering replacement key fobs.
Back everything (metaphorically) up a little bit first aswell....
What's actually going on with the vehicle - what's working/not working etc, and how has it been diagnosed that the ECU needs repair (and which one as the others have mentioned).
It *could* be that something external to the ECU is causing the problem and the ECU itself is actually fine - but we can't help diagnose it/confirm diagnosis if we have no information to go on!
I apologize for delay in reply. Returned home after six months away; mice had moved into engine compartment, etc... Cleaned and replaced visibly damaged hoses, etc... Fuel pump went out; had replaced with OEM. Drove fine; days later she would turn over but any of the following shut engine down: use of wipers, turn signal, tap on break, etc... instrument cluster went out. Car is now paperweight at my house. British mechanic said ecu was bad and needed some attention to the tune of $600. Couldn't come up with contact in SoCal; couldn't find anyone else since mechanics here say they don't send ECU out. My mechanic later said not ECU at all but to check alternator and battery (?). Anyway, thank you for reading. Please let me know if further detail would be helpful. Regards,
your issues are not any ECU you need a new engine harness before you start replacing stuff
Super Moderator
Wipers, turn signal or brake pedal switch don't go anywhere near the engine harness. It sounds more like a bad earth connection (as Bolt has already suggested in your other thread) or a failing underbonnet fusebox.
Discussion Starter #10
I appreciate your knowledge, Richard. Thank you. Regards
1 - 10 of 10 Posts
