HAD TO HAVE BATTERY REPLACED, RADIO AND HVAC WILL NOT TURN ON.. I HAVE CHANGED THE RELAYS, WHAT ELSE IS THERE PLEASE HELP
Hi, welcome to forum but you're in the classic RR area here so the guy's with p38 knowledge may not see and help you.
Worth reposting in the p38 section to get help.
They're both fed from the same fuse under the bonnet - can't remember which one but you might also have a faulty fuse box. They fail over time. Start by checking all the fuses first.
THANK YOU FOR YOUR RESPONSE - I HAVE JUST CHECKED ALL OF THE FUSES AND ALL ARE OK... THE BACK LIGHT OF THE HVAC PANEL IS LIT UP, WHICH CONFUSES ME.. ALSO I JUST SPOKE TO THE RANGE ROVER DEALERSHIP CLOSES TO ME AND HE BELIEVES CODES WERE ADDED, SUPPOSEDLY 2001 P38 DID NOT HAVE THEM TO BEGIN WITH. I BELIEVE HE WOULD NOT ANSER MY QUESTIONS...
