HELLO, THIS IS MY PROBLEM... WENT TO OPEN AND START MY P38. I OPENED DOOR WITH KEY (remote broke years ago), alarm went off. Tried to insert key to turn over...engine disabled reading. Tried reset using key with NAS general code 1515, did not work. Since I think the problem is a worn out lock switch, which I am ok with replacing myself, but can anyone tell me how to get the engine to start or how I can get into neutral so I can tow it on a flat bed home to do the work.
Thanks so much for your reply.
Best always, Steve
JACK'S GRANDAD
Easiest way to get it into neutral is to remove the shifter cable from the transmission. Undo the nut, remove the cable and turn the lever by hand with pliers.
Martin
Banned
Insert a fuse into position 11 to put the transfer box into neutral for towing. It won''t matter what gear the actual gearbox is in then.
Absolutly the way to go. The fuse position is in the drivers seat fuse box ( side of drivers seat ) I have towed a car 70 miles in that state with no ill effects as there was no other practical way. You will get a message in the dash readout something like "transfer neutral". The position in the fusebox is normally empty so just pop in a spare.
re fuse - there will not be a fuse in place otherwise you'd not be able to get any gears :) that's why it's empty at the moment - its covered in the cars handbook.... if you've a faultmate you can enter the eka via that even if the lock is 'fubar'
Very Much Thanks to all of you! Worked perfect... now at home for new parts and then back on the road.
Steve from Cardiff
R
Guest
does the becm allow acces to put in EKA when alarm is armed and engine locked?
Yes, the BECM has a setting to enable the EKA code and the EKA code must be written to the BECM. This is not done at the factory in all cases. If the car has locked you out and the engine has become disabled because of an alarmed state, you can activate the EKA code which may unarm the alarmed condition. Below are some of the settings avail..
BECM SETTINGS
SUNROOFFOG LIGHTSDAYLIGHT RUNNING
Fitted
Not Fitted
Rear SidelightsFront and Rear Sidelights
Rear Dipped BeamFront and Rear Main Beam
Rear Main Beam
Disabled
Dipped Beam and Sidelights
Sidelights
TRIP COMPUTERKEY WARNINGCAT AMP/HEATERDRIVE
Fitted
Not Fitted
Disabled
Enabled
Fitted
Not Fitted
Right HD
Left HD
EKASPEED LIMITMARKETGEARBOX
Enabled
Disabled
100
120
Not Set
Set
Auto
Manual
BECM STATUSENGINESERVICE LIGHT
Unlocked
Locked
MotronicGEMS
Early EDCLate EDC
Disabled
Enabled
RANGE LAMPIMMOBILIZERLAZY LOCKING1 TOUCH
Enabled
Disabled
Disabled
Enabled
1 Shot Key Only
1 Shot Key and FOB
DMH Key Only
DMH Key and FOB
Drivers
Front
All
None
WINDOW CANCELLANGUAGEARM/DISARM
Disabled
Doors
Ignition Off
English
French
German
Italian
Spanish
Dutch
Portuguese
Code Book
Hazards
Side and Tail
ALARMWIPER SPEEDCRUISEMOISTURE DETECT
Enabled
Disabled
Enabled
Disabled
Set
Not Set
Enabled
Disabled
MISLOCKUK POLICEALARM NOISESOUNDER
Sounder
Interior Light
Police
Normal
Single
Pulsed
Klaxson
BBUS
ALARM LIGHTSBECM CURRENT ALARMED STATUSCURRENT EKA LOCKOUT STATUS
Hazards
Side and Tail
Dip and Tail
Alarmed
Disarmed
Unknown
Lockout
Normal
Unknown
EMS CODEVINDATE OF BUILD (dd/mm/yyyy)
MILEAGEEKAFOB CODE
