I have this big screen in center console same as this picture.
Car came with blurry TV reception, and with remote (SONY) saying 3 big button on top: T.V, NAVI, ITALY.
Pressing any key on remote have no effect even after i inserted new batteries. Looks like remote is bad, is there any way i can switch screen to Navi mode from TV mode w/o remote. I can only see one switch next to speedometer to switch this screen on/off.
Any luck in getting updated maps for this nav if somehow i start it up??????
That looks like a O.E Phillips/Vdo Dayton screen to me which which I don't think ever had a TV facility or Remote Control.
It might be possible someone has converted it to accept TV transmissions which may explain why the picture quality is poor. Somewhere there must be a reciever to accept the signals, be it for TV or Sat Nav.
The O.E navigation unit is normaly fitted in a housing located in the boot. Unless this has been change for a Sony Unit of some kind I'm not sure what the Sony remote is of any use for unless someone has been able to convert this to opereate the system.
It doesn't appear to have the nav equipment in the "boot" so it may be a TV.
The antenna on the roof looks like it is laying down which may be causing the bad reception.
hmm thnks Terry. May be i was searching something that never existed.
TV antenna thingy i figured out later but still no luck with clear signal. Will probably insert some VHS to see if it show good quality video (just for fun).
I have 6 CD changer in boot inside left side of trunk space. Is Nav unit is separate?
