Replaced the battery and now it will not start.. The steering column is locked and will not release. I'm told I need a re set but not sure what that involves. Maybe a code?
I live in West Ga. near I-20 if anyone knows a good RR mechanic please advise.
Sure it's a 2000? That would be a P38 where the steering lock is purely mechanical, the later 2002 onwards L322 has an electric steering lock that may well need a reset after a battery change.
If it's really a P38, you should have a warning of "engine immobilized" or similar. If that's the case you'll need to enter the unlocking code on driver's door. (it's in a small card) and according to the numbers, it's a left and right movements of the lock with the key.
