Hi.
Just looking for a heads up.
Have the Front Passenger Window gone faulty on me some week ago.
Bucked up the courage to take the door apart to look into it.
Thought I might have found the problem with a 'loom' of relays looking quite wet laying in the bottom of the door sill. Looks like at some point in the past they have been drilled off the door frame. (Assuming that's where they where factory fitted)
However not so sure if its a case of just straight replacement Relays and fit them in a better postion.
Not having a wiring diagram, have no idea to check inputs/outputs etc.
Also the power connecter to the motor had a bit of insulation removed, either by chafing or a previous owner checking voltages, etc.
When I press the Window DOWN Button I get a click from one of the relays. But NO Voltage on the Grey Motor Leads. However, on depressing UP I also get a click from the relay and 6.5V on the Grey White lead.
As I said not having a wiring diagram I am just assuming the relays are the problem.
However, I find it strange to not see where the two Grey Power leads to the motor are coming from. Is there another terminal/unit behind the galvanised panel ?
Any help greatly appreciated.
Mike
Mike
