I recently purchased a 2000 Range Rover 4.6 HSE. The previous owner had completed the Coil Conversion prior to my purchasing and I was able to fix the EAS message using the information I found on this board. Since then, I have come up with a few other problems. Any help you could offer diagnosing these issues would be SINCERELY appreciated.
1. ABS Fault / Traction failure
I was getting these two messages and, based on the search function, assumed that I needed a new battery. Today I went to purchase one. It turns out that my battery was new 08/08 and tested perfectly on the Autozone equipment.
Next I will check the ABS sensors. Do you think these two faults are related?
2. I had the car professionally detailed. When I picked it up I developed two additional problems...
The driver side rear window will not stay up. When I press the "up" switch on the console I can hear a relay clicking, but nothing happens. the window will roll up if I press the up switch on both the console and the door at the same time. Sometimes it will stay up for a few seconds, sometimes it won't. But, in the end, it always rolls down.
Additionally, since the detailing, I am now also getting beeping and a message that says, "KEY IN IGNITION", even when the key ISN'T in the ignition.
Finally, none of the amber warning lights on the dash will illuminate. I have assumed the worst - that the previous owner has pulled bulbs - but I figured I would throw this in case it may be somehow related.
On a happy note, an inspection at the dealer during the oil service came out pretty positive with the exception of a few leaks (Oil Pan and Front Differential).
Thanks in advance if you can help.
Jeff
Jeff
