i have recently replaced the the pump, eas, and air suspension. but i notice the when the car is off and in park it will move up and down by itself. sometimes it will be in normal drive position and move up to high, and other times will drop all the way down.
The vehicle self levels every so often and if it receives an invalid height sensor signal it may well do what you are witnessing.Try removing the EAS timer relay under the left front seat and see what happens then.If it then lowers one side only you have a air leak.
