Fuel pressure -Ok
Spark -Yes..
No alarm or error code display..
But still not fire up..
BUT when i pour some fuel into body throttle..it fire up for a while..and shut..
What else should i look?
Thanks dud.. need your experiance and advice.. as newbie here..
And thanks again..
pressure ok..on fuel reel..and had change fuel pump ..and injector too..anything else..to check..
if yo have fuel at the rail you now have to work out if the injectors are firing or not, could be loose wire if you have been working on it or some interlock that is stopping them from firing . if the vehicle hasn't run for two years it could be lots of things . has it ran since you had vehicle.
