1999 4.0 Gems ~ code reader can't read! Having some running issues, took to my mechanic, he says when he plugs in the diagnostic machine, it shows nothing. And it's not his machine that ain't working. Second problem: engine stutters when running. Symptoms:
Kevin in Minneapolis. Thanks much!
- when cold, idle goes up to 1800
- when cold, driving, press lightly on accelerator and engine cuts out completely for about a second, then with more gas pedal, it runs fine. Still has "cut out" problem when accelerator pressed lightly.
- when warmed up, idle eventually comes down to normal (around 900 rpm). Engine still cuts on but for much shorter duration under acceleration.
