I'm having problems with my sump gasket it has blown for the 4th time this year so far and was wondering if I can put a thor sump on the gems engine as i believe the gems sump may be warped. does anyone know if this can be done and if so was it a successful swap?
Banned
and if it is warped it's only a steel pressing. Take it off, lay it on a flat surface and go around the edges with a hammer to get the mating face flat again.
It is a pressed stee pan yes, but has a pressed lip. Beating it with a hammer would ruin the pan. Proper installation with a heavy bead of sealant will take care of any flaws and/or warpage.
Banned
Yes it is but I've seen a couple where the edge has been bent where someone has hammered a screwdriver in to lever it off as the original sh*t to a blanket sealant didn't want to let go. I wasn't intending that anyone would bash the whole thing flat, just straighten up any bent bits.
Still not needed. Make sure block, front cover and pan are clean, apply bead, install with only 4 or 6 bolts and only tight enough for bead to make contact with the block/front cover, wait 15 minutes then install remaining bolts/nuts and finger tighten, wait an additional 15 minutes and snug up the bolts. The beat will have filled any irregularities and both surfaces will have a clean seal. If you just slap the pan in place and torque it up the sealant is forced out the sides leaving little if any to maintain a seal.
