Hi, I really need help from you guys,
To make a long story short, I took my P38 to be deep cleaned. When I came back the car was outside with the hood open and battery disconnected. They said the alarm had gone of. When I reconnected the battery, the horn was on full blast, and the wipers (front window, lights), windows, and washing liquid where all going nuts, and the siren as well a little later. I managed to drive most of the way home, by taking out fuses for all of the above. Got 90% af the way home, when the car started to loose power and starting "turning on and off" for a little bit, and then died, making a bad smell in the process. Was able to park it and later tow it the rest of the way (did that correctly btw).
I dried the car for 48 hours, assuming the deep cleaning guys had wet some of the electronics. I also charged the battery. After the 48 hours, all the electronics where back to normal. But...I can't start the car. It says "Gearbox fault" in the dash board. I have checked all the smaller fuses, they are all OK.
I have read everything there is to read online, and I have gathered that this is probably a low voltage thing. However, the battery is fully charged, and I have tried jumpstarting the car. Even tried waiting a few minutes with the cables attached (to a Ford E-150). Nothing worked. Most recently I tried the blackbox ECU immobilizer reset that I got from a local, but that didn't work either.
And now I am out of solutions. Can anyone help?
