I oped the Fuse box and on the Green plug I can see brown stuff. Is that because the fuse box has burned.
What is the function of the green plug.??
I also saw burn marks on yellow plug and Blue plug.
They're relays.
Read the back of the fuse box lid to tell you what they are for. They should be listed in your manual also.
And yes...your fuse box is getting hot and cooking the relays. I bet there's a bunch of cracks in the plastic of the box as well? That's why they need to be replaced before long.
Mine is bad and makes one of the a/c fans cut out occasionally... which isn't fun in Florida summer.
I don't remember any blue relays Kmags - just yellow and green....
What I believe is probably being talked about, is the large 40mm/1.5" square plugs under the fusebox - these come in lots of colours.
Brown marks do mean you fusebox has been cooking itself though - too much current going through it.
I'm so glad I had my breakdown insurance, that was one more thing that the policy covered...
