I broke this part and I don't know what to order for a replacement. Can you tell me what part this is? It is the green plastic end of a wire connected to a multi plug below the coolant tank. 20180207_152652.jpg
That is part of your wiring harness. Your best bet will be to find a P38 in a wrecking yard near you and snag that connect with a tail and splice it in place.
Super Moderator
Green two way connector with Black and Green wires looks like the temperature gauge sensor connector. In fact, if you look carefully at your picture you can see the green coloured sender on the top of the inlet manifold behind the alternator where it should connect. If you can't find the correct connector, get two small spade terminals and put them on the end of the wires so you can plug them in.
