Is your EAS intact? I’m guessing not as you mentioned “springs”, so I’m guessing you have coil springs, not the stock airbladder springs that were stock in ‘95.The owners manual says 72", but my LWB measures at about 69" in height from floor to roof. I just put new springs on and they were stock height springs. What should the height be, and why would I be short?
I measure 17" from center of hub to fender archCompare center of hub to fender arch.
Standard heights are in the Rave manual.
No air springs. CoilsIs your EAS intact? I’m guessing not as you mentioned “springs”, so I’m guessing you have coil springs, not the stock airbladder springs that were stock in ‘95.
That’s the difference...No air springs. Coils
With the original EAS, you could adjust the height. Access level was lower, and fully articulated, would have been higher.The owners manual actually says 70.8 inches not 72 like I previously wrote.
I don't have access to my data but I recall normal rife height should be 19" front and a bit less rear.I measure 17" from center of hub to fender arch
They are brand new springsI don't have access to my data but I recall normal rife height should be 19" front and a bit less rear.
Sagging Springs.
Since the vehicle never came with springs, who's to say your new springs are the right choice for your vehicle.They are brand new springs
