1 - 10 of 10 Posts
hi my name is rick i have a 1995 range rover classic lwb with a shifting problem in order to go in to reverse i have to go down to first gear then back up to reverse and thats the only way it will go in to reverse and when i try to just put it in drive it acts like its in second gear and at about 45-50 mph it keaps going in between gears like it does not know which one to pick.if any of you know what this problem is please reply and tell me :D
Don't buy a new transmission yet. I have a friend in Washington that is going to look into the problem for me. My transmission shifts just fine if you manually shift it. It does not slip and when I changed the fluid it did not have any thing bad looking in the pan. I have got to get the transmission identification numbers and send them to him and he will look into it. Also from what I have read it could be the governor that is sticking causing the problem or some valve. If I find out what the problem is I will post it here. Thanks
Could it be related to the linkage between the gear selector and the transmission? A friend had a similar problem in his old VW Jetta and it turned out that a clip had broken that locates the shift cable in the console. I'd definitely check this out before looking at replacing transmission. Maybe disconnect shift cable and shift it on the transmission itself and see what happens.
1 - 10 of 10 Posts
