off the top of my head check all the breather hoses between plenum chamber and rockers and ensure no leaks between maf and plenum? maybe its sucking in air somewhere. Mines done that a few times.
You dont mention which engine you have, year model..... if its pre 99 then I would say two things, 1 HT leads 2 idle control valve on throttle body, maybe throttle position sensor but I doubt it.kooky_guy said:This doesn't help, but mine intermittently does exactly the same thing. While it's doing it, I also get a very low idle speed and stalling. It never seems to do it first thing in the morning though which seems a bit odd. It usually only does it after starting the engine when it's warm...
It's recently (last couple of days) got much worse for some reason.
I've had a new MAF which seemed to fix it for a while. More recently the adaptive values were reset in the ecu again which seemed to cure if for a while, but it's back again now and it's REALLY irritating especially in the snow!
Guy
I am assuming GEMS going by the thread title..viperover said:You dont mention which engine you have, year model.....
Cheers. Pretty sure the HT is ok. I'll see if i can get the values read. Does Rovacom show the same values?allyv8 said:If the HT side of the ignition system is in good order the only other thing that springs to mind is if the stored closed throttle voltage is too low.If its less than about 0.6v this will cause hesitation or stalling from idle.The stored and actual throttle voltage can be seem on Testbook.
