My 1993 SWB has a heated windscreen, which is apparent from the filaments visible in the glass and the presence of the heated front screen (HFS) switch on the dash. When I depress the switch it illuminates, I hear the relay click under the driver's kick panel, and after one second the switch goes dark and no power to the HFS.
I bought a replacement HFS timer. This thing:
Having removed the driver's side kick panel I cannot find this part. I found the black HFS relay as well as plenty of other relays and timers, but I can't locate this timer. I can't find any diagrams in my copy of RAVE that show where the timer should be. I would be grateful for a detailed description or - even better - a photo or treasure map that shows its position. It may be possible that I'm looking in the wrong area altogether.
