Re: 1992-93 RR classic 3.9 Over heat when up hills or traffic
in attempting to read between the lines I would say you have an air bubble in your cooling system. nest guess would be a failing waterpump or radiator. then would be a blown head gasket.
please fill in your profile with location to hel us out and add your rig to your signature
Can it be fan viscous coupling??
Rgds:Jukka
RR92 Westminster 4.6
-73 Rover P6 3500 Efi
I had this problem with my 91 RRC. It turned out to be the two rear cylinder sleeves had separated from the block. There were no coolant leaks, oil leaks or any other signs. Just the over heating when going up hill or sitting in traffic. I ended up having to replace the block. When I did I opted to upgrade to the 4.6 block and nearly everything from the 3.9 fit on it.
