1970-1995 Range Rover P38A
I'm working on my old classic. It's been sitting for about 6 mouths. I had to charge the battery as I have had it disconnected. When I started it I have the following lights on. Both blinkers, trailer, check engine, ABS, BRAKE, Radiator fluid low, OVERTEMP, and seatbelt.
Checked Battery while running the alternator is putting out 13.9.
No headlights.
any ideas where to start?
Thanks,
Chuck
1995-2002 Range Rover Classic
check engine, read code reader under seat. abs, will go out when you drive over 10 mph. overtempt, check coolant. brake fluid low check fluid.
blinkers check the hazard switch and the impact sensor. seatbelt you're on your own, as far as I can remember older rovers never had seatbelt buckle reminder.
Thank you for the electrical trouble shooting manual. I did not have one for my RRC. I'll start by looking at the inserment cluster.
