1 - 20 of 38 Posts
New to the forums and LR ownership but couldn't be happier so far with this rig. I have wanted one of these since I worked at a Range Rover dealer when I was in college. After almost a year of searching for a rust free, clean history car, I was lucky to find her local to me.
Picked her up a couple months ago. It had about 160k on the clock, clean history and needing some work, but nothing too crazy. Let me preface this thread with the fact that I have limited mechanical knowledge, so a lot of that work will be done by the Pros..
Here is what she looked like just after picking her up:
First order of business was to have the bubbling and blue tint removed as well as a proper paint correction (Tint removed by detail shop and correction done by myself)
Next was on to the cracking wood. I began by removing the trim and sanding it down as best I could. I used some very inexpensive and basic wood look vinyl to wrap the panels as I wanted to keep it easy and cost effective. I could also quickly remove and change it down the road if I ever wanted to change up the look:
The bubbling and blue tint needed to be removed as well as a proper paint correction (Tint removed by detail shop and correction done by myself)
Discussion Starter · #6 ·
After this the whole A/C system was converted to R134a. I know this tends to be a controversial modification in regards to its effectiveness, but the stock system was shot and it made sense to overhaul the system since the tech had to be in there anyway. So far it has been excellent. At the same time, I had the oil changed, diff fluid changed, brakes done and the fuel filter changed as well. I have been daily driving it for two months now and it has been running fantastic!
Next were the wheels. I went with a black finish to go with the look I was after:
Discussion Starter · #7 ·
Then it came time for the biggest job yet on the truck. I wanted to give it some proper insulation and sound deadening. I dont want this truck to be a garage queen and this would make it much easier to daily drive. As you will see, she is a rust free example! Here are some of the progress photos:
WOW this is a very comprehensive job you are doing.
Real good to see you are saving (and dare I say spending money) on an old Range Rover. Inevitable old cars will fall into neglect this is just how it is, but some cars are luck and are kept nice or rescued.
You need to see it a little bit as a hobby really, but still very satisfying to see an old Rangy getting looked after. With all that work I am sure you will enjoy it much more than buying just another new(ish) truck!
Keep up the good work and thanks for sharing your work. I already spotted a few idea's for my own car in your pictures!
Discussion Starter · #10 ·
@JS5D Thanks for the kind words! I want to preserve the character of the old Range Rover as much as possible, but bring it up to modern standards.
New Body Bushings and a full set of Poly Bushings for the suspension are in route and will be installed in the coming weeks. This should make a huge impact on how it drives as she is very "Floaty" right now.
Also in the works will be a new Carpet Kit and Headliner.
Discussion Starter · #12 ·
Bushing Overhaul Time! New body bushings and suspension bushings arrived today. Also not pictured is a new Bilstein steering damper. I wont be installing them for a few weeks, but I hope they make a significant difference.
1995-2002 Range Rover Classic
just a heads up.
be careful with the Bilstein steering damper, my 95 developed a drift to the right side and heavy steering after installing one of these units back in 2005. did not cause uneven tire wear but my wrist would get tired on long trips from holding the wheel from turning right.
turned out to be the billie damper had constant extend pressure thus emulated turning and the drift. I reinstalled a factory unit and problem solved.
Discussion Starter · #14 ·
just a heads up.
Thanks for the heads up! It currently has a Terrafirma damper on it, but I have no idea when it was installed. Luckily I will have that as a spare in the case this one does not work properly.
Can you provide a link to the material you used for the wood trim covering?
I am a big fan of those TF ones, they resist bad, really bad roads nicely. That is what I have in my classic.
Congrats on your buy, part of my body was a dark grey and I was glad to have it painted light green & white living in a hot climate. If you need a respray one day think of it, I have never regretted it and suffer the more in my darkish green Disco.
Discussion Starter · #17 ·
Nothing Fancy: http://a.co/eyY4n6x
I would keep the TF if I knew the age/condition of it. Figured if I were doing new bushings I would go ahead and try the Bilstein. Currently it is very floaty and all over the road, so hoping it will help quite a bit.
Discussion Starter · #18 ·
Well I paid the Rover Tax this weekend.... After washing it, I turned it back on and it was making a horrible squealing noise. Had it towed to my mechanic and they diagnosed it as a broken idler pulley? Said it sounded worse than it really was. It is still there having the body bushings and suspension bushings done. I am very excited to get it back to see how much of a difference they make.
Looking good, Beluga Black? Has to be by fave color for a RRC.
Would love to see this with the front spoiler, chromed bumpers and factory profile tyres.
Was the sound deadening worth the effort? Thinking of doing it to mine.
Let us know how the suspension upgrade goes...
Discussion Starter · #20 ·
The Front Spoiler is definitely being considered, and I agree that black is a very fitting color for the Range Rovers.
I haven't had a real chance to test the sound deadening as I need to get the speakers and carpets done to get the full effect. What I have noticed though is that the car does seem to stay cooler. I guess the A/C doesn't have to work quite so hard. I also haven't done the roof yet, which I imagine will have a significant effect.
I am not a huge fan of chrome. I didnt specifically mention it in the above posts, but in the photo below, you can actually see that I refinished the rear bumper in gloss black as well as the side caps. It helps the bumper look more like a fluid piece with the body rather than just tacked onto the back of the truck. The faded plastics and pitted chrome didnt do any favors for the appearance.
1 - 20 of 38 Posts
