Hi,
Can anyone tell me if 2 door RRC doors are available to buy new.
Also in the process of upgrading headlamps.
I'm assuming the sealed beams are just one bulb, I.e no side light as the guy selling the new lamps asking asking if I require H4 kits with Sidelight, I don't think so but if someone can confirm
Cheers.
Dean
I dont believe I have ever seen repro 2 door door parts. Rovers North used to sell 4 door parts. They would be my first point of contact.
JACK'S GRANDAD
Thinking he's in England Carl...... At least thats the Doncaster I know.
Martin
Check with Rimmer Bros, Craddocks, and Paddocks. You should be able to find at least the door skins. If you need complete doors, I'd check with your local breakers.
Give this lot a try, http://www.kingsleycars.co.uk/ they restore 2 and 4 door RRC's, if Herritage or someone else is producing them they would know... Failing that you could try Land Rover as they have just started reconditioning 2 Door RRC's.... just don't let them do yours... unless you've a spare £135K :shock:
