chem said:I want some 19" rims that will fit Brembo's....
apart from the stock 19" rims on the range rover sport, what other stock (aka cheap) 19" rims are out there that will fit over the brembos?
So 19" by cpw-inc are 06/07/08 Land Rover Range Rover HSE OEM Wheels which will fit in 09 RRSSc with Brembo? Since these are OWM, the (d)stealer will be able to install em?TripleE said:There is a vendor (cpw-inc) on ebay that sells the RRS 19s for $300 w/o tires when they have them. They are typically take offs.
EDIT: FF set right here: http://cgi.ebay.com/ebaymotors/2006-200 ... 3a52ca0f3e
Yeah, why didn't you post the results! Checking (255/55/19 vs. 285/50/20) the 19s would be 1" shorter but have basically the same sidewall (2mm difference). I'm thinking maybe they are not wanting to use the spacer on the 285/50/20 (is that what you did?)?Drevs said:Why do you ppl want 19's instead of 20's for offroading? Have you compared the effective sidewall height and overall diameter between the available 19 and 20 inch tires?
I knew you'd do it for me :wink:TripleE said:Yeah, why didn't you post the results!
If you can get away w/out wheel spacers I would. I am dealing with a recurring wheel bearing failure issue on my FJ, due in large part (I think) to extra stress on the bearing from the spacers. I just went down in width on the tire and got rid of the spacers and we'll see if that helps.Drevs said:I knew you'd do it for me :wink:TripleE said:Yeah, why didn't you post the results!
It's not really a big deal, but I think you can get away w/o the spacer; I'm going to give it a shot today. If you never see another post from me, well, just use the spacer :lol:
