I've had my truck sitting and she's giving me a gearbox fault once I insert the key. I know this is a 12V issue. But my question is: I've disable my engine and I can't synchronize my key fob because I believe she's not able to produce the 12Vs. Does this seem like a reasonable conclusion ?
Have you charged/checked your battery? If not that would be a pretty good start. Have you checked and cleaned your grounds and cables? Does it do anything at all?
Well my batter was disconnects for a while. I know she's pushing out under 12V because I'm getting a gearbox fault message. I figured she need the 12v also for resyncing too
Until you have basic electricity it makes no sense to even bother with further guessing or testing. CHarge your battery and go from there.
Thanks bro. That's an reasonable answer that gives me some relief. As logical as it is regardless.
