The Range Rover P38 has a 12v accessory plug in the rear of the truck from 2000-2002. Unfortunately, it is wired into the ignition so it only works when the ignition is on. Since I want to use this socket to run my ARB fridge/freezer, I need it to be 'live' all the time. On the opposite side (drivers) Land Rover had a plug wired for an accessory and is not used. It has a 'hot' 12V and an ignition 12V source. I rewired the 12V 'hot' wire and ran it under the carpet along the tailgate to the other side into the accessory plug so I can run my fridge. Its an easy mod but a worthwhile one when you want a cold beer on the trail.
Pic of the accessory plug and panel to remove to get to wiring.
Pic of the interior piece over the subwoofer that must be removed to access the un-used plug.
Pic of the wiring completed on the drivers side and the plug reattached to fender wall.
Pic of accessory plug re-wired
The ARB looks great in the back of the Rangie with a cold brewski at the end of the day.
Nice I just installed the 2000 set up including the fuel door opener in my 96 when I installed the 2000 interior in my Rangi. I tap into a Purple wire in tail gate harness on the same side where the power outlet is located. Love It! :clap:
Scotty
