So I wanted more noise but disnt want to chop up factory pipes and weld stuff up so after a bit of planning...
The tips of rear cans are 2.375 od with 2.25 id. Called up local auto supply I use and had them send me 3 feet of 2.25 od pipe. The pipe enters rear can about 2.5 inches so after some quick measuring cut 2 pieces 13.5 long so they would slide all the way in and approx .25 past original tips. These pipes slide in about 9" and then need hammered in rest of way. Use a cut off piece to beat on so you don't mushroom good pipe and tap them all the way in.
Exhaust note is nice and is exactly same as cutting off rear cans but can be done in driveway with a sawzall a file and a hammer in a minimal amount of time.
