Question for the Braintrust
Has anyone done a Brembo GT or Rotora upgrade to their new style range rover? Im curious as to the difference in braking (assuming you do only the fronts)
Some questions:
1) Both the Brembo and Rotora packages "disable the ebrake" - I thought the ebrake was only for the rears. Am I wrong? What is the benefit?
2) Can you only change out the fronts or do you need to do the rears also (ie will there be a brake imbalance)
3) Do you need to change the brake booster?
4) How much better is the OEM Brembo SC setup than the standard HSE setup - and are the rears different also?
Thanks in Advance
An OEM upgrade is about $1400 and the others are $3500 and up
Some questions:
Thanks in Advance
