Hi all, I'm new to the forum and new to RR...love it so far. Anyways a question on getting the Droid phonebook transferred through bluetooth. Is that possible? I'm sorry if already covered...I did try the search but didn't see anything. TIA
Once you sync it up, it should download all of your contacts. If you hit the phone button and then turn the right dial on the radio, you will see them all.
If you have a 2007 with factory PTI / Bluetooth module by Nokia, you will probably need a software update to be able to download phonebooks from your Droid to the Sport. Up until late MY08 production, the modules did not have that capability built in. After the upgrade, your Moto Droid should be compatible, with some likely limitations (only one phone number per contact may be downloaded.)
To check compatibility of certain BT phones with your car's VIN: http://www.landrover.com/Microsites/GWS ... rket=us-en ;
For more info on the phonebook-over-Bluetooth software upgrade: viewtopic.php?f=5&t=24359
