Hi all! Forgive me for the novel I’m about to write. Whew, here we go. **KEEP IN MIND: I have been anal about maintaining and repairing any/everything per LR/manual specifications **
I Was driving home and he engine was noticeably hesitant and “sputtering”almost as if it wanted to stall. I thought it was perhaps dirty spark plugs, however not 20 sec later, Engine light(amber) started flashing, with “reduced engine performance”. I was “creeping” to the parking lot right next to me, and engine stalled while driving. Instinctively I went to recrank,which it did, but stalled out again. I was able to re crank a second time and coast into parking lot. I immediately plugged my basic engine obd2 in, and got random misfires on all cylinders. P0300-p0308. The only codes I had prior to this incident were p0171 and p0174(running lean), however I had cleaned maf and changed air filter, and hadn’t gotten those codes again. I had truck towed home, and a mobile mechanic came to “diagnose” it. He is able to crank it right up and it doesn’t stall out for the 15 min it’s running, but it was running rough. Sounded like A “heavy Chevy” and was shaking. He never did give me the codes and diagnostics bc he said he’d have to research further. (That wasn’t going to work for me) I let it sit without cranking for a cpl weeks, and when I went to crank it, the battery(less than a yr old) was completely drained. I jumped it but it was shaking violently and barely made it to the other side of driveway before stalling out. I removed battery terminals and have checked all fuses, relays, cleaned intake & hose(connected to maf),repaired muffler and rear pipe leaks, but couldn’t find any other exhaust coolant or intake leaks. I did notice there was a small puddle of oil inside the intake manifold. I haven’t gotten it out yet, bc im not sure if it’s supposed to be there or not. I know that I need to change plugs and prob coils, but I can’t keep the truck running long enough to figure that or anything else out. I switched relays around to see if I might need a new fuel relay, jumped it and it shook and stalled right out. I even tried to give it some gas to keep it running and it felt like there was almost no response to the accelerator pedal. NOW, I have oil seeping out of every seal, bolt, crease/side, pcv, the bottom of where you pour oil into, the top of oil dip stick and around all he coils/plugs(both sides)no oil is dripping onto driveway, but it’s def seeping out from every pet of head. No fluid levels are low, oil isn’t milky, and I’m at a loss. Going to check the fuel filter and pump but any suggestions would be greatly appreciated. I’m so fed up with 1 step forward and 3 steps back.
Re: PLEASE HELP!! 07 L322 4.2L SC sudden engine issues and
would change fuel filter and do an intake service, clean TB (on account of the oil you mentioned as this can cause rough idle). report back. Mine did the exact same thing when the fuel filter fully clogged one night... shuttered and died... restarted it able to limp it home, died in the garage. Would run intermittently for minutes then shaking and stall. Fuel pressure was erratic. When I pulled the fuel filter and banged it against the table an awesome amount of junk poured out of it. Either it reached a critical level or it all at once sucked up a bunch of garbage in the fuel tank. Even if this doesn't turn out to be your issue it's a good place to start... takes about 40 min to replace the filter. With your misfires and lean condition I'd be looking at fuel delivery for sure, pump could be bad also.
Hi Kelbel5582, Every mechanical engine needs GAS to run; G -for gasoline, A -for air and S -for spark. Your issues are 2 folds, gasoline is not getting to the engine in good quantity so the engine is not running good. Check fuel pump and filter. The second issue is that you might have damaged your positive crankcase ventilation(PCV) system with repeated cranking and engine running rough.
Work on the 2, i believe your truck will be back to its former self. Thanks.
I have similar problem, flashing mil light, rep and sometimes shaking like stripper
couldnt find the issue for months.
If you dont have 0308 code was better. 8-7th cylinders are pia in our town.
Check compression on 8th and 7th
dont buy any parts you can buy half a vehicle on land rovers but it doesn’t solve anything
Clean tb check the sound from pcv valve if very noisy you have to replace
