06 RRSC Rear Brake Piston Source? Need to rebuild and replace piston
Hi I've been looking around and I'm finding the front pistons but not locating the rears. I live in a high salt usage area and the rear brake pistons are rusted up. I had one locked up caliper over the weekend. With some work I got it to move and cleaned up the surface on the piston and put it back together and it's working fine again but I would feel a lot better with a new piston. Am I stuck only buying a full caliper which seems like a waste as the caliper is fine other than the $5-$10 piston being in rough shape.
I'm in the US but would be okay with shipping from the UK if need be.
Thank you
Discussion Starter #2
Re: 06 RRSC Rear Brake Piston Source? Need to rebuild and replace piston
Never mind found RockAuto has CENTRIC 14122515 & 14122516 Reman; Premium Semi-Loaded Calipers for $38. Not worth messing around with for the price I'll just buy the calipers and swap them. Rover parts places all wanted around $175 from what I saw. What are they smokin? Even the Brembo fronts are only $132!!!!
