04 Range Rover clucking sound over small bumps at slow speed.
I have a 2004 Range Rover with 100K Miles on it, she is no good condition never been off road, recently I started to hear a "Clunk" whenever I went over a bump in the road at slow speed. I have change the sway bar, I have also changed the sway bar links and well as the upper control arms. Yet the clunk persists, the Range Rover Dealer said everything looks tight and could find nothing loose are worn after the fore mentioned parts were changed out.
Any ideas?
Re: 04 Range Rover clucking sound over small bumps at slow speed.
How are the upper strut mounts? Lower control arms?
Ok I will check them out when I go back in on Friday.
Mine started making a similar clunking noise right before the air strut have out. I'm not sure exactly what caused the noise but it stopped after the replacement.
Not trying to scare you with anecdotal evidence, but if you haven't changed the struts ever you may want to have them checked. Or just order a pair from Arnott to be safe.
