hi guys, so i have a weird problem going on with my 04 rover. The air compressor will run continuosly but it will only lift the rear left wheel and then throw a suspension inactive. I checked the live data using my handheld and it shows that only the left rear valve bellow is opening. Everything else is normal from temperature to pressure. There are no leaks anywhere and the compressor is recently rebuilt and putting out great pressure. the weird part is that i have a foxwell handheld where it allows me to lift the car using it. when using the handheld, the car will raise on all 4 corners perfectly fine and quickly. im completely lost as to what to check. Theres no leaks, compressor is fine. can it possibly be the rear valve block? any help would be greatly appreciated. thanks
