New 18" and 20" All Terrain tires - Page 9
Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 121 to 132 of 132
Thread: New 18" and 20" All Terrain tires
  1. #121
    LIFETIME CONTRIBUTOR Brimill1234's Avatar
    January 14th, 2013
    Holmdel, NJ
    1,379
    Re: New 18" and 20" All Terrain tires
    Quote Originally Posted by rover7 View Post
    They are balanced perfectly and feel smooth as silk up to 100mph (ran out road) haha .
    Mhmmm.... Well I guess we all can't drive like me....
    2013 RRS HSE LUX Santorini black
    QuickSilver Exhaust
    20" Redbourne Nottinghams
    I am a professional so please use caution, I may have enjoyed a few cocktails when I told you to go ahead and try this at home...
  3. #122
    January 7th, 2014
    SE USA
    36
    Did you ever get your wheels rebalanced? I mounted up my Cooper Zeon LTZs last night and I couldn't be happier. They are balanced perfectly and feel smooth as silk up to 100mph (ran out of road) haha. And they're not noisy at all considering the aggressive tread pattern.
    I haven't yet. hoping to one day this week. seems the steering wheel wobble is the worst around 60mph. definitely not up to par.
    2010 RRS Lux Nara Bronze
    2010 LR4 Premium Alaska White
  4. #123
    October 3rd, 2016
    Europe
    12
    Quote Originally Posted by umbertob View Post
    frinsan, where have you been buddy? The wheel arches of the Sport do have some extra wiggle room to allow for larger tires than the factory ones without issues other than your speedo / odometer being off proporationately. As a rule of thumb, tires with a total diameter of about 31.5" or less should fit without rubbing on either wheel wells or shocks. Your stock 20" rims are wide enough to take 285/50 tires. If you can live with the speedo telling you are going 60 when you are really going 65, these tires would be a good choice for off roading with a S/C Sport, since 18s aren't an option and nobody seems to make 19s all terrains other than those Wrangler MTRs we cannot get in North America.
    You all seem to talk only about S/C model (= SuperCharged, right?)
    What about other RRS models? For example I have 3.6 Litre Diesel 2009 year model. Will same sized tires (up to 31.5") fit it as well or are there some differences between these models regarding max. tire size?
  6. #124
    Premium Member MI2VA's Avatar
    July 16th, 2013
    Roanoke Virginia
    487
    Max wheel diameter on 06-09 sport is 32" and that will have some rub in the rear wheel wells. I believe max width on same trucks is 285. The only limitation between the HSE and SC is rim diameter due to Brembo brakes on the SC which limit the rim to no less than 19". The HSE can accommodate as small as 18" rims.
    '06 RRS LUX
    '06 pilot EXL
    '91 4runner
    2006 RRS LUX, Rimini Red, Alpaca leather, 275/65 R18 Terra Grappler G2s, 1.5" lift, RSE, reclining rear seats, Resonator delete (all), SAT
  7. #125
    March 11th, 2014
    California
    318
    I bought a second set Of 18" wheels for my 06 sport hse - and put a used set of 255/60-18 hankook dynapro atm's on ... Road noise , ride and handling not significantly different from my 19" Pirelli scorpion street tires - did an off-road weekend with landrover club and the tires were great - almost no traction loss on sandy, rutted trails - last year on the pirellis I had to get the sand ladders out at least once ....
    Only downside I can see is that these are rated 107t versus 112v xl .... As long as you keep speed close to us legal and are not planning to tow or exceed 8000lb loaded weight I think that should be ok ....tire temp after freeway run at 80mph was fine ....
  8. #126
    October 3rd, 2016
    Europe
    12
    Quote Originally Posted by MI2VA View Post
    Funny, I have same Brembo brakes on 3.6 diesel model, which also limit rim size to min 19".
    But maybe in USA they do it differently...
  9. #127
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    There is an after market solution for S/C or Brembo brake equipped vehicles...you can get the 8x18 Compomotive wheels (UK based), and those will fit. Should be a lot cheaper I should imagine in EU than in the U.S. due to shippping expenses, although you may have to pay higher VAT as well. That's a good alternative.
    PJPR
    13 Orkney Grey RRS HSE Lux
    06 Cairns Blue RRS HSE (200K...sold to a friend)
  10. #128
    October 3rd, 2016
    Europe
    12
    I already have 20 inch original Land Rover rims, which came with the car, so I'm not very keen in buying new ones.
  11. #129
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Quote Originally Posted by archangelus View Post
    No one is forcing you to buy another set of rims - you indicated you were limited to the 19 inch rim, I'm letting you know that there is an alternative available in the 8x18 configuration with Compomotive. Whether you buy them or not is up to you...
    PJPR
  12. #130
    September 7th, 2015
    Long Beach, CA
    Buying the Compomotives was the best decision I ever made. 2nd was the IIDTool! Well, maybe they're tied
  13. #131
    July 28th, 2016
    Salt Lake City
    28
    I thought the compomotive 18s would not fit the 2010+ SC?
  14. #132
    11,013
    They won't. They'll fit 2009 and earlier S/C, or 2010+ models without the high-performance brakes, such as the S/C here in North America.
  1. Ditching 22" Tires and Going to Stock 19"
    By pdocken in forum Range Rover Mark III / L322
    Last Post: May 10th, 2011, 04:08 PM
  2. All Terrain Tires for 20" Wheels
    By GregS96 in forum Range Rover Mark III / L322
    Last Post: April 21st, 2011, 09:28 AM
  3. Offroading with "all-season" tires
    By gkwait in forum Range Rover Sport / L320
    Last Post: October 7th, 2010, 10:28 AM
  4. "Lift"/ Tires/ and wheels opinions wanted
    By endneu913 in forum Range Rover Mark II / P38
    Last Post: October 19th, 2009, 05:19 AM
  5. Finally...19" + 20" snow tires
    By PARR06 in forum Range Rover Mark III / L322
    Last Post: August 20th, 2006, 06:59 AM
