winter/ sumer tires
Results 1 to 8 of 8
Thread: winter/ sumer tires
    September 7th, 2006
    95
    winter/ sumer tires
    is it ok to keep winter tires on during the summer?
    does it have to do with the soft composit of a winter tire that if you keep them on during the summer they will be that much softer and possibly blow out that much easier due to the heat?
    thank you
    January 21st, 2007
    Germany / Austria
    53
    just as summer tires are not suited for winter, winter tires are not suited for summer. you will get alot longer breaking distances, your abrasion will increase enormously and you just won't have the grip you get from good summer tires
    Premium Member drdread's Avatar
    February 9th, 2007
    NY-NJ-CT
    305
    IMO...
    The bottom line issue is you will wear out the winter tires so drastically in summer driving that they will be like all seasons the ensuing winter & probably like contis the following winter.
    I disagree necessarily with performance related issues as the pirelli scorpion... & other equivalent high performance winters, have excellent road performance, each with excellent speed & weight ratings, so they perform almost as well as even summer tires, they will just be eaten up in the heat.
    Yes the traditional truck winter tires suck in anything but winter driving, but the ones designed for this type of SPORT utility are less prone to have the traditional winter tire issues.
    '06 Java Black on Black FFRR SC
    '06 Cairns RRS HSE Lux (sold)
    '94 D90
    '94 RRC LWB
    September 7th, 2006
    95
    thanks for the answers
    Premium Member Frisco_TX_RRS's Avatar
    April 8th, 2007
    Frisco TX
    1,245
    Summer/winter tires are more determined by what the temperature will be. Summer tires should not be run when outside temps hit 40-45 and below (very short periods are OK)
    September 7th, 2006
    95
    how about keeping Winter tires on during the Summer?
    April 8th, 2007
    Frisco TX
    1,245
    They are softer, and can overheat and blow out. Depends where you live - Texas in July, and people drive at higher speeds for longer mileage in 100 degree+ heat which could be a problem, but not much in a cooler region of the country.
    Another issue is that winter tires use a different rubber compound. You'll eat up most of the tread in a summer. Due to tread design they also tend to be noisier and depending on the aggressiveness of the pattern it can guzzle more gas.
    See Tirerack article too - http://www.tirerack.com/winter/tech/tec ... techid=120
    February 2nd, 2006
    Pleasantville, NY
    384
    if you get nokian WRs you will be fine. Ive used them all year round for years and i get 20,000 miles out of them no problem.
  1. Winter Tires vs. All-Season Tires
    By Darrin in forum Range Rover Mark III / L322
    Last Post: November 23rd, 2011, 01:42 PM
  2. Winter Tires
    By eball77 in forum Range Rover Sport / L320
    Last Post: November 25th, 2008, 11:37 PM
  3. winter tires
    By cherminator in forum Range Rover Mark III / L322
    Last Post: December 1st, 2007, 05:37 AM
  4. SC with Winter tires
    By 1953 in forum Range Rover Mark III / L322
    Last Post: September 11th, 2007, 07:30 AM
  5. Winter tyres (tires)
    By jensputzier in forum Range Rover Mark III / L322
    Last Post: September 20th, 2005, 07:18 AM
