Oil change (suction method) MY2010-13 - Video - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 51 of 51
Thread: Oil change (suction method) MY2010-13 - Video
  1. #46
    March 11th, 2014
    California
    319
    I tried to do this on my '06 4.4 v8 hse - could only get 1/2 the oil out - does dipstick tube placement preclude this on that model - or did anyone have success ? Also used mityvac
  3. #47
    27,613
    Re: Oil change (suction method) MY2010-13 - Video
    I think you will find the dip stick tubes do not go all the way to the bottom on older engines.
  4. #48
    LIFETIME CONTRIBUTOR Brimill1234's Avatar
    January 14th, 2013
    Holmdel, NJ
    1,382
    Did you just connect to dipstick tube or did you use one of the supplied smaller tubes and run it down the dipstick hole into oil pan? There are smaller hoses that come with it that you slide down into oil pan to use auction method
    2013 RRS HSE LUX Santorini black
    QuickSilver Exhaust
    20" Redbourne Nottinghams
    I am a professional so please use caution, I may have enjoyed a few cocktails when I told you to go ahead and try this at home...
  6. #49
    JUNIOR ROVER Canrover's Avatar
    December 15th, 2014
    Gloucester
    795
    Quote Originally Posted by Canrover View Post
    Hey Umberto,
    I just did my second oil change and there is one thing I'd like to warn everyone about that is not in your DIY vid. The little metal tube that you stick the suction hose into seems quite delicate. When you stick the hose on it, yes it is a perfect snug fit but since the hose runs down the car and into the reservoir it puts a little bit of lateral pressure on the delicate metal tube. Over time the tube can crack rendering it useless. My remedy is to wedge in a bit of paper towel between the metal tube and the sides of the access port to keep it from being moved as the hose sucks the oil out.
    Just changed my oil today and thought I'd take this photo to show how I keep the suction tube from moving to the side.
    Attached Thumbnails Attached Thumbnails Oil change (suction method) MY2010-13 - Video-img_2981.jpg
    "I know the voices aren't real but man do they ever come up with great ideas!" 2010 Range Rover Sport Supercharged, Santorini Black with ebony interior and Alcantera seats
  7. #50
    11,013
    As long as that paper towel "bumper" doesn't break and/or move and fall into the oil cap opening while you aren't looking... Personally, I have never felt like I was putting that much pressure on the suction pipe when connecting the rubber fitting to it, it's a small pipe but doesn't look that delicate to me. However, as shown in the video I always leave the fitting attached to the plastic hose from the Mightvac when I connect or disconnect it from that pipe, last thing I want to do is fumble the little sucker and watch it disappear into that dark opening (things get slippery in that area, so... Murphy's Law.)
  8. #51
    December 15th, 2014
    Gloucester
    795
    That doesn't really worry me but I do fear a small piece of tissue coming loose so I just make sure to krumple it up tight so no fibers come loose.
    As for the thin tube I find it's too delicate for my taste hence the tissue.
  1. oil change question! (oil brand)
    By kim0217 in forum Range Rover Sport / L320
    Last Post: September 23rd, 2013, 05:36 AM
  2. MY2010-11 Smart key low level repair video
    Last Post: July 2nd, 2013, 01:36 PM
  3. Replies: 5
    Last Post: January 17th, 2013, 06:48 AM
  4. Oil Change
    By The Doc in forum Range Rover Sport / L320
    Last Post: October 13th, 2010, 01:25 PM
  5. ADVICE NEEDED: Engine oil/transmission additives/Oil Change
    By HollerLWB in forum Range Rover Classic
    Last Post: April 4th, 2007, 07:03 AM
