Zerk / Grease Points?
Results 1 to 5 of 5
Thread: Zerk / Grease Points?
    May 21st, 2008
    110
    Anyone have a list of all the zerk / grease points on this vehicle? Thanks.
    September 12th, 2007
    5,175
    Re: Zerk / Grease Points?
    Its a good question but I haven't found any yet. Grease fittings are going the way of the dinosaurs. I still have to periodically grease the U-joint on the driveshaft in my Toyota, I have not seen similar instructions for the RRS. I suppose I should crawl under there and check or perhaps Dave will stop by this thread.
    '08 RRS HSE Stornoway Gray
    April 28th, 2013
    Northern Virginia
    2,467
    There are none.
    There is one u-joint in the drive line, and it is not servicable, there rest are CV joints and considered filled for life. There are no slip joints in either shaft either, lateral play is made up in the CVs.
    None of the ball joints have grease fittings either(at least that I have ever seen or serviced)
    The good news in this, is that these components don't fail very often at all. A member recently reported a rear drive shaft failure, but I have never seen one. The ball joints don't fail too often either, and when they do, it is generally not in a way that grease would have helped (play, not binding, although wear from grease loss will cause play, but they don't loose their grease often either)
    Dave
    Land Rover Master Tech
    5,175
    Well there u have it. Thanks Dave.
    January 16th, 2007
    ID
    1,657
    It's nice having you around Dave, thanks.
    '07 RRS
    '03 325i
    '94 GSX
  1. Grease Points on LM 322
    By L4FLIROP in forum Range Rover Mark III / L322
    Last Post: April 16th, 2012, 04:21 PM
  2. Where to grease gun?
    By nuyorican420 in forum Range Rover Mark II / P38
    Last Post: February 22nd, 2012, 01:58 PM
  3. The best zerk fitting (broken one) remover- Any ideas?
    By TheoR in forum Range Rover Mark II / P38
    Last Post: April 19th, 2010, 03:47 PM
  4. Grease fittings
    Last Post: January 22nd, 2007, 01:28 PM
  5. Hub Grease ??
    By johnw in forum Range Rover Classic
    Last Post: July 10th, 2006, 07:59 AM
