Latch on upper Stowage Box - is it replaceable?
Results 1 to 15 of 15
Thread: Latch on upper Stowage Box - is it replaceable?
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Hey guys with the detailed Topix design access...
    Is it possible to replace just the latch on the upper Stowage glove box rather than replacing the entire door itself?
    Mine broke on the left hand side yesterday, it seems that the plastic gave way finally and I'm just checking first if that latch on the 06 RRS can be replaced or if I should buy the whole door (about $150).
    Thanks!
    PJPR
    13 Orkney Grey RRS HSE Lux
    06 Cairns Blue RRS HSE (200K...sold to a friend)
    LIFETIME CONTRIBUTOR Brimill1234's Avatar
    January 14th, 2013
    Holmdel, NJ
    1,382
    Re: Latch on upper Stowage Box - is it replaceable?
    Is just the latch available to buy? Typically if a single part can be bought then it can be replaced by itself.
    2013 RRS HSE LUX Santorini black
    QuickSilver Exhaust
    20" Redbourne Nottinghams
    I am a professional so please use caution, I may have enjoyed a few cocktails when I told you to go ahead and try this at home...
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Quote Originally Posted by Brimill1234 View Post
    Yup...I"m still searching for the answer on that...have a call into the LR parts dept. and awaiting a reply, but I didn't see anything on Ebay at the moment for just the latch yet. Still looking!
    PJPR
    September 12th, 2007
    5,175
    Does it come in anodized blue?
    P.S. I have nothing constructive to add, just felt like contributing to the thread.
    '08 RRS HSE Stornoway Gray
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Good call...but for the interior, it would have to be Zebrano Wood to match the rest of the interior!
    PJPR
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Just got confirmation that it does NOT come separately...so will try to use some Gorilla Glue to re-attach the plastic, and failing that, will have to buy a new one for $150. Despite this breakage, I'm actually quite happy, as this is the first mechanical part to actually "fail" after almost 8 years on the interior. I better fix it and sell it fast!
    PJPR
    11,013
    Paul, is the part you are looking for listed here? I see a striker and a clip... Not sure if either ones would fix your issue for less than a new $150+ door.
    5,175
    Paul, if you do end up fixing it with glue I'd use a two part epoxy and not Gorilla glue.
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Thanks Umberto, in that box 8 there is a small indentation on top of the door where the latch is, unfortunately it doesn't look like a separate part here. I checked Ebay, they have one new in Alpaca for $150, the dealer club price is $153...so pretty close.
    Good advice Mike...will try that first.
    Hey...we can start a bumper and glove box repair business soon!
    PJPR
    5,175
    On the epoxy a good rule of thumb is the longer the set the stronger the bond --5 min versions being the weakest bond. You have to balance out how long you need to hold the piece in place to set. In your case if you can fix it in there and go with the longer cure it's best.
    My favorites are the Hardman bubble packs if you can find them...
    http://www.grainger.com/Grainger/epo.../N-84wZ1z0qa9o
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Ok...weekend project coming up! Thanks again!
    PJPR
    5,175
    This weekend's "Weekend Project" on rangerovers.net brought to you by PJPR01
    January 14th, 2013
    Holmdel, NJ
    1,382
    Or you can ship it to me in PAand I can do a staple melt and plastic weld on it. Epoxy is going to be a crap shoot on a latch.
    QuickSilver Exhaust
    5,175
    Tough to beat that offer!
    PJPR01, doesn't HP own a stake in Stratasys? You could get them to 3D print a new piece.
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    That's a lot of effort just to fix a glovebox latch! But it's good to know that I've got a backup plan here and can outsource it to B. man in case I can't fix it! Appreciate the offers guys!
    PJPR
  1. Glove Box release/latch mechanism?
    By bharris68 in forum Range Rover Mark II / P38
    Last Post: January 7th, 2014, 05:00 PM
  2. What part is this? Part of the bumper or replaceable individually?
    By Golfer1659 in forum Range Rover Sport / L320
    Last Post: December 28th, 2011, 09:28 PM
  3. Drivers door latch/fuse box
    By rangeroverb in forum Range Rover Mark II / P38
    Last Post: April 18th, 2010, 07:02 AM
  4. Glove box latch
    By maggasp in forum Range Rover Mark II / P38
    Last Post: August 18th, 2006, 12:58 AM
  5. Did you know... Damaged remote key buttons are replaceable
    By Brett San Diego in forum Range Rover Mark II / P38
    Last Post: March 21st, 2006, 07:49 AM
