Water dripping from dome light
Results 1 to 5 of 5
Thread: Water dripping from dome light
    FRESHMAN ROVER Rover75's Avatar
    June 13th, 2013
    Sw fl
    67
    I know tis has been discussed to a degree. I found a post on here that explains how to check and repair tubes if needed. All my tubes seem to be draining properly, but at highway speeds we get drips of water from dome light when it's raining. Any suggestions other than not driving at highway speeds during rain storms, haha, I'm sure I beat someone to their punch line.
    2006 Range Rover Sport 100,000 miles
    2004 Discovery 2 190,000 miles
    1998 discovery 1 76,000 miles - sold
    "MOLON LOBE"
    27,609
    Re: Water dripping from dome light
    ...and you ahve already checked the seal around your glass, trims and sunroof alignment as noted in other threads?
    FOUNDING MEMBER Iceberg's Avatar
    April 30th, 2004
    Sacramento
    1,418
    How is the front windscreen seal?
    Also, after a rain do you hear gurgling up there? Mine had a kink in one tube that did not stop but slowed drainage. It also channeled some water to the key lock antenna because of the kink.
    Proceed Until Apprehended
    June 13th, 2013
    Sw fl
    67
    I don't hear any gurgling, all the seals seem fine, one thing I haven't checked is the glass alignment, I'll do some searching on how to check that. It seems if the glass was leaking around the edges that there would be more water? The dripping is so slight I wouldn't even bother with it, but I'm afraid of water building up in the headliner or somewhere where it could do harm.
    "MOLON LOBE"
    April 30th, 2004
    Sacramento
    1,418
    It was the drip at higher speed that is odd. I had mine just starting out after sitting in the rain, and it was sunroof drain related. The seals are great, but keep the drains clear. I could hear it before it dripped. Like I said before, if it is coming out there, it is also likely going places that will be even more annoying later, so it is worth playing with a hose on a sunny day. That is what the dealer would do, your water is cheaper.
  1. 2012 Range Rover Sport dome light leaking water
    By Wg12684 in forum Range Rover Sport / L320
    Last Post: February 19th, 2018, 01:29 PM
  2. Dome light housing.
    By Armogida in forum Range Rover Sport / L320
    Last Post: April 29th, 2014, 02:47 PM
  3. Water dripping from Dome light
    By rover4.0 in forum Range Rover Mark II / P38
    Last Post: March 17th, 2009, 05:22 PM
  4. Dome light troubles
    By One4adventure in forum Range Rover Mark II / P38
    Last Post: November 6th, 2007, 07:25 AM
  5. Interior Dome Light
    By in forum Range Rover Classic
    Last Post: July 20th, 2005, 10:25 AM
