Coolant Temp Sensor R/R
Results 1 to 6 of 6
Thread: Coolant Temp Sensor R/R
    July 26th, 2009
    Hello all,
    I recently purchased a replacement coolant sensor due to a CEL I received a few weeks ago. Would anyone have any tips, pics or instructions on removing and replacing the coolant sensor?
    November 4th, 2012
    Maui
    10
    Re: Coolant Temp Sensor R/R
    What does it do?
    July 26th, 2009
    Quote Originally Posted by milroy View Post
    What does it do?
    I don't remember what the code detail was exactly but it was something along the lines of coolant sensor voltage below threshold. Seemingly as a result of the faulty sensor, the temp gauge rarely ever makes it up the the middle range.
    July 26th, 2009
    Any input here? I guess I'll try following rad hoses and hopefully I'll run into it.
    June 24th, 2012
    canada
    762
    Quote Originally Posted by TSTARKZ123 View Post
    Hello all,
    Here's what I found-- for the 4.4 L--
    "ENGINE COOLANT TEMPERATURE SENSOR (ECT)
    The sensor is located at the front of the engine in the water pipe below the throttle body. The ECT sensor is a thermistor used to
    monitor the engine coolant temperature. The engine coolant temperature sensor is vital to the correct running of the engine as a
    richer mixture is required at lower block temperatures for good quality starts and smooth running, leaning off as the temperature
    rises to maintain emissions and performance.
    The sensor has an operating temperature range of -30 Degrees Celsius to 125 Degrees Celsius. When a defective coolant sensor
    is detected, the ECM uses the oil temperature sensor value.
    July 26th, 2009
    Quote Originally Posted by arby View Post
    Thanks a ton! I already received the replacement part and hope to install it over the weekend.
  1. Coolant Temp sensor
    By Shawna in forum Range Rover Mark II / P38
    Last Post: September 30th, 2012, 04:30 AM
  2. Coolant Temp Sensor Connector
    By Jarlath Norman in forum Range Rover Mark II / P38
    Last Post: August 19th, 2011, 09:37 AM
  3. Engine Coolant Temp Sensor(s)
    By Vladimir in forum Range Rover Mark II / P38
    Last Post: March 25th, 2011, 11:52 AM
  4. coolant temp sensor
    By modjunkie in forum Range Rover Classic
    Last Post: September 27th, 2010, 11:09 AM
  5. Coolant temp sensor/water temp sensor...
    By nedrover in forum Range Rover Classic
    Last Post: March 8th, 2005, 09:53 PM
