Xenon bulb/ballast reinstallation
Results 1 to 3 of 3
Thread: Xenon bulb/ballast reinstallation
    June 18th, 2012
    Wenham, MA
    I have removed the lamp assembly and installed a new xenon bulb. Having a tough time re-installing the ballast(?) on the back of the bulb & assembly. Appears to be a simple key way/twist on and it came off easily enough but... What am I missing?
    December 8th, 2012
    Malvern
    Re: Xenon bulb/ballast reinstallation
    Can you provide me with any help? I am having the same problem. Thanks for the help.
    FRESHMAN ROVER velocity's Avatar
    November 11th, 2011
    Canada
    18
    try installing the ballast first and then plug the connector, when you remove ballast it unplugs when you spin it and if you plug it in before turning it to install it wont allow to sit where it is suppost to be.
  1. Swapped xenon ballast...
    By umitbat in forum Range Rover Mark III / L322
    Last Post: April 10th, 2012, 01:44 AM
  2. Bi Xenon Bulb Replacement
    By isleofbones in forum Range Rover Mark III / L322
    Last Post: March 4th, 2011, 08:25 PM
  3. Xenon Bulb Replacement
    By HugeBob in forum Range Rover Sport / L320
    Last Post: July 22nd, 2010, 11:43 AM
  4. Xenon bulb replacement
    By chronoguy in forum Range Rover Sport / L320
    Last Post: February 13th, 2007, 12:27 PM
  5. Xenon Bulb
    By Dizzle in forum Range Rover Mark III / L322
    Last Post: December 21st, 2005, 03:57 PM
