2006 Range Rover Sport HSE noise (differentials?)
Results 1 to 2 of 2
Thread: 2006 Range Rover Sport HSE noise (differentials?)
    NEWBIE Landonrover's Avatar
    February 19th, 2019
    california
    Hello, I'm new to this forum I bought a 2006 Range Rover Sport w/ 135,000 miles about 7 months ago. I absolutely LOVE it! however I have a had a few hiccups since then and I still can't figure them out.
    First, when i go on the high way about 55+ mph it starts making a humming noise from the back of the cabin. It stops as soon as you take your foot off the peddle and continues when you push back on the gas. I took it to to an independent shop were they replaced my sway bar (which fixed one problem) and said they checked the wheel bearings and they said they were fine.
    Secondly, I went over a speed bump, and a metallic POP POP POP came from what seemed like the back axle (differential?). The speed bump is rather tall and narrow compared to others and it has only happened on that speed bump?!? I came to a complete stop then went and it continued popping, then reverse still a pop. I gently babied it about 1,000 feet with it popping and then it stopped and drives smooth until i'd go over that speed bump again. Awhile back I had a transmission fault message followed by "limited gears available" "HDC fault" and it put itself in to limp mode, however my battery was bad during this time so i got a new one and haven't had these messages since (knock on wood). I don't know if these are connected to the popping?
    Thanks for reading any thoughts?
    January 30th, 2019
    Oregon
    15
    Re: 2006 Range Rover Sport HSE noise (differentials?)
    Hi Landon,
    In trying to help here, I'm curious;
    #1 Does the humming on the freeway matter if you're going uphill, downhill, flat, sweeping at freeway speeds to the right or left? Does the humming change at all?
    #2 Have you had the rear diff fluid changed at all, checked for metal/debris?
    The faults could have been caused by low battery voltage for sure--have they returned at all?
    Very curious to hear a resolution.
    '06 RRS 4.2SC
  1. How tell if you have electronic differentials RR-HSE 2004
    By Basque1 in forum Range Rover Mark III / L322
    Last Post: January 25th, 2016, 05:51 AM
  2. What differentials are in the 2006 Range Rover Supercharged
    By davepl in forum Range Rover Mark III / L322
    Last Post: May 8th, 2013, 07:06 PM
  3. Differentials Demystified
    By Malafax_dand in forum Range Rover Mark II / P38
    Last Post: June 27th, 2007, 09:00 AM
  4. differentials
    By rangerrick in forum Range Rover Classic
    Last Post: September 7th, 2006, 08:32 PM
  5. Both differentials leaking
    Last Post: August 17th, 2005, 05:51 AM
