System Charging Fault. Battery and alt are working normally
Results 1 to 9 of 9
Thread: System Charging Fault. Battery and alt are working normally
    June 4th, 2017
    North Florida
    9
    Guys,
    I cannot figure out what is wrong. Today, I had my windows tinted and while they tinted the windows they kept a charger on the battery. Well, when I was getting ready to leave the battery light and critical warning light came on as well as the "System Charging Fault" light came on. I had the battery and alternator tested at two different auto parts stores and they both said that everything is fine.
    I have disconnected the battery for longer than 1 hour and reconnected and I am still getting the fault light. Anyone have any clues as to what is going on? Seems to be an electrical issue that needs to "reset" because the battery is getting the proper charge.
    Any suggestions will be greatly appreciated.
    October 25th, 2018
    Re: System Charging Fault. Battery and alt are working norm
    Doctorphil - Did you find out how to fix it?
    January 23rd, 2019
    Ontario Canada
    66
    Bump...
    Got the same issue here too!
    Please reply
    November 22nd, 2014
    Hessmer, Louisiana
    107
    Perhaps 'hard re-set' is needed.
    I think you disconnect the positive & neg. terminals, tough them together for 5 seconds ....
    But research it on here, don't recall the specifics
    July 21st, 2011
    Virginia Beach, VA
    462
    I think a hard reset might work: detach the negative cable and touch it to the positive post. Drains all capacitors. When you reattach the negative cable, tighten both cables and the connectors at the junction -- sounds like your problem is either a loose battery or a bad ground.
    Cheers, Jim
    2017 Lincoln Continental Select 2.7 AWD; 2013 RRSport HSE, 40000 miles (traded); 2001 Jaguar XJ8L X308 BRG 89000 miles (traded on RRS); 08 RRSport SC (sold); 08 LR 3 (traded); 05 LR 3 4.2 (traded); 04 BMW Z4 sold; 01 XJ8 anthracite (for LR 3); 98 Z3 (traded on Z4); 01 S-type 4.0 V8 (traded on XJ8; 99 323 IC (traded on S-type); 94 Deville traded; 88 325IS sold
    January 23rd, 2019
    Ontario Canada
    66
    Didn't help in my case....
    Sent from my SM-G965W using Tapatalk
    2013 3DR Evoque Dynamic 2.0 GTDIS
    July 21st, 2011
    Virginia Beach, VA
    462
    Ok; so what did work? New battery? Surely by now, you have running.
    Cheers, Jim
    January 23rd, 2019
    Ontario Canada
    66
    Quote Originally Posted by jhartz View Post
    Still have issue, actually...
    Have you checked my other thread?
    January 23rd, 2019
    Ontario Canada
    66
    https://www.rangerovers.net/forum/sh...d.php?t=332156
  1. Battery / Charging System Fault - Help needed
    By bacoverdale in forum Range Rover Sport II / L494
    Last Post: April 6th, 2017, 10:04 AM
  2. Intermittent High Idle, Gbox Fault, Alt. Fault on start
    By mpalmer7 in forum Range Rover Mark II / P38
    Last Post: February 27th, 2017, 12:54 PM
  3. Charging System Fault
    By MarkbRRV2010 in forum Range Rover Mark III / L322
    Last Post: September 19th, 2016, 10:39 PM
  4. Charging system fault
    Last Post: September 13th, 2016, 03:08 PM
