Front Windows Will Not Roll Down - Page 6
Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 80 of 80
Thread: Front Windows Will Not Roll Down
  1. #76
    27,607
    Re: Front Windows Will Not Roll Down
    Quote Originally Posted by RoverGuy7 View Post
    ... it would help to know what country you're in to be sure you're checking the correct passenger's side.
    Thus the reason we ask for a real location in profiles and that folks use proper LEFT or RIGHT terms instead of local slang like driver and passenger...
  3. #77
    February 3rd, 2017
    London
    Ok I am near giving up here, someone please give me just a little bit more information, I have a 2005 range rover sport Right hand drive (UK) and I have checked both door sills and no black and grey wires, I did find 3 black wires going into one black wire, is this the splice people are on about? if so I have rewired all factory splices that I can find and I've had no luck.
  4. #78
    January 8th, 2017
    SoCal
    80
    I would have to hazard a guess, but I think the wires would be on your passenger side if that is where the fuse box is. Personally, I went through both sill wiring looms and fixed about 3 or 4 corroded splices, including one mid-way to the fuse box which gave juice to the sunroof. (thought the water would not have effected that high up but it did...)
    Pull apart both sides and do it right- even if there are not issues today, the corrosion will not stop and you will have other "mystery" gremlins.
  6. #79
    April 8th, 2018
    LaGrange, Kentucky
    Had the same problem. Driver side window and front passenger window would not operate from master control on driver side. Other indications that its a ground fault on my 2006 sport is that i could remove the 25amp fuse position #7, this is the fuse for the driver side window, and could get the front passenger window to work from both driver side and passenger window control but still could not get driver side window to operate. Also verified that I had power going to main switch driver side and to the window actuator on the driver side. All is working now. 3 Gray/black wires are on passenger side front third of the opening and they did show corrosion. I don't believe my moonroof drain is my problem but found a lot of moisture either from spilled sodas or coffee.
  7. #80
    July 8th, 2019
    Seattle, WA, USA
    this is my very first post on this forum, but i just wanted to say THANK YOU!
    also, here's a zoomed out pic of the wire splice location, for those not sure where to look. i located the crimp/splice right where the tip of my wire tool is.
    what a lousy connector that it! even if it didn't get wet... i gave it a tug and the actual wires were disintegrated and the tip just popped off. i couldn't reach my soldering iron out to the street without getting another extension cord, so i stuffed all three wires into one end of a blue gauge butt connector, crimped the shiz out of it, wrapped it in electrical tape, folded it over and ziptied it.
  1. Anti Roll Bars leaking front and back...
    By Nani in forum Range Rover Sport / L320
    Last Post: July 28th, 2011, 05:04 PM
  2. S/C Front Anti Roll Bar Bushes Knocking
    By carlos50 in forum Range Rover Sport / L320
    Last Post: October 17th, 2010, 12:20 PM
  3. Closing front doors with windows down
    By solihullv8 in forum Range Rover Mark II / P38
    Last Post: March 7th, 2009, 07:18 AM
  4. Front anti-roll bar upgrade
    By andymc0001 in forum Range Rover Mark III / L322
    Last Post: July 16th, 2008, 02:12 AM
  5. Help! Wifes RR. Front windows won't roll. Door won't open.
    By thunder92 in forum Range Rover Mark II / P38
    Last Post: August 7th, 2007, 01:39 PM
