Gas cap warning light keep coming on. Any ideas?
Results 1 to 6 of 6
Thread: Gas cap warning light keep coming on. Any ideas?
    August 20th, 2015
    seattle, washington
    2010 Range Rover Sport Supercharged. 78k Miles.
    So almost everyday now I will get a message saying "Check Fuel cap". Is this common? I've put a new cap on too even. Problem is still there. I do every one in a while get a light for catalytic convertor below threshold. Could that be related to this? I feel so that my car is no so torquey either as it should be at times.
    within the last 500 miles. I have done my fuel injectors and spark plugs.
    Any ideas?
    October 17th, 2018
    Re: Gas cap warning light keep coming on. Any ideas?
    I have the same issue. Hopefully someone will be browsing this site and have some answers that they can share.
    April 19th, 2019
    there's most likely a sucking noise / gargling noise coming from near your gas cap. this means the charcoal canister needs to be replaced. they all go bad over time.
    December 22nd, 2018
    New York
    i have 2011 sport supercharged- my issue was the purge vale- simple to replace...
    if you ever overfill at the gas station, you send the fuel into the canister, which should be free of fuel...and it goes bad.
    March 9th, 2018
    Phoenix, AZ
    122
    Wow good to know. Until now I've always topped off after the gas pump automatically shuts off the first time. I won't be doing that any more.
    June 5th, 2018
    144
    Actually, this code is typically created when the gas cap is loose or leaking, but can occur anytime the system attempts a leakdown test, and it fails. The system knows the capacity of the tank, and the fuel level in the tank due to the fuel gauge. During the leakdown test, the system attempts to create a vacuum in the tank by pulling a vacuum on the tank. A sensor in the tank tells the ECM when a vacuum is created. If, for some reason, the tank sensor fails to report a vacuum within a certain time, the fuel cap light is illuminated. Any leak in the system can cause the failure, including a leak in the vacuum system, or a leak in the vapor side of the tank, including the vapor canister or lines. Ray
  1. Check engine light on due to missing gas cap that won't turn off
    By Cspine in forum Range Rover Mark III / L322
    Last Post: February 13th, 2015, 12:01 PM
  2. check engine light gas cap
    By Mirage in forum Range Rover Mark III / L322
    Last Post: June 25th, 2013, 07:03 AM
  3. Gas Cap Loose Msg/Stuck gas gauge
    By BMWRover in forum Range Rover Mark III / L322
    Last Post: May 24th, 2012, 07:47 AM
  4. Air bag warning light coming on
    By sportman in forum Range Rover Sport / L320
    Last Post: May 13th, 2007, 05:41 PM
  5. Check Engine Light on 2006 (gas cap?)
    By lawrencejay in forum Range Rover Mark III / L322
    Last Post: June 12th, 2006, 07:37 AM
