Need Brakes @ 22.5k for 08 S/C - Page 4
Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 46 to 60 of 135
Thread: Need Brakes @ 22.5k for 08 S/C
  1. #46
    January 16th, 2007
    ID
    1,657
    Re: Need Brakes @ 22.5k for 08 S/C
    Quote Originally Posted by gooseyloosey
    Mine looks a bit different than yours goose:
    And I dropped the little sensor clip you warned me about (even after thinking about it); where the f is it?
    Oh, way over behind my feet...
    Had a little left:
    So if you've never played with the sensor on the Sport, it's a little tricky as said before. Once I got it in the first time, I really couldn't tell it was in. So I took it back out to double check. When I put it back in...
    '07 RRS
    '03 325i
    '94 GSX
  3. #47
    September 12th, 2007
    5,175
    Nice 3E!
    Now the bottle in the middle wouldn'ta had anything to do with the other things, would it?
    '08 RRS HSE Stornoway Gray
  4. #48
    January 16th, 2007
    ID
    1,657
    What?! That bottle was my strengthening serum - just like your liquid wrench! Really, thanks for your DIY, it was so helpful to know the pitfalls before hand.
    In case you didn't notice, that is my "finger" in the last pic.
    '07 RRS
    '03 325i
    '94 GSX
  6. #49
    January 16th, 2007
    ID
    1,657
    Since I Hans Rey'd (but crashed) the front brake sensor and I didn't see goose's pics after the plastic surgery on his arm, I thought I owed it.
    Where the sensor enters the liner:
    I took out 2 of the plastic grommet thingys (pleasantly surprised at how they come out compared to other makes); then wedged something in to hold the liner about where my hand is so I could have both hands free:
    What it looks like from the front of the wheel well looking back:
    Close up; top is the sensor wire that is replaced, bottom is the connector that stays:
    My new wire came with a different mount that holds only the sensor wire so I took it off (screw/mount partially slid out towards the bottom):
    My old mount holds additional wires, so I slid the old sensor out of the mount (it has notches, but check out how the new one works first, it's the same, just takes some force):
    Then just slide the new wire onto the old mount.
    '07 RRS
    '03 325i
    '94 GSX
  7. #50
    July 2nd, 2006
    It's a dry heat
    1,737
    What?! I just showed you how to repair the original!
  8. #51
    April 11th, 2010
    44
    Why do the rotors need to be replaced so frequently? I thought they're supposed to have a longer lifespan than the pads, but it seems like most recommend replacing both at the same time
  9. #52
    5,175
    Nice pics showing how that's done 3E!
    Hey Drevs, some of us can't solder as nice as you, especially after a few Blue Moons, or as in my case, inhaling brake cleaner.
    Quote Originally Posted by opotamus
    They do, you probably can get two pads worth out of the front rotors and definitely two out of the back. Its a heavy car though and if the rotors get to thin, I think they are prone to warping.
  10. #53
    January 16th, 2007
    ID
    1,657
    Thanks, I have small hands.
    Yeah, and plus, the S/C front sensor is totally different!
    '07 RRS
    '03 325i
    '94 GSX
  11. #54
    July 2nd, 2006
    It's a dry heat
    1,737
    Well ****, you need me to do a tutorial on that too??
  12. #55
    October 15th, 2007
    Chicago
    235
    Great info! Thanks so much for the detailed write-up.
    Just curious, are there any different procedures I need to do for S/C model with Brembos?
    Also, do you raise the vehicle first using hydraulic ride height control before jacking up the car?
    Thanks!
  13. #56
    5,175
    Quote Originally Posted by sbkim
    Thanks!
    No, don't raise it. Just lock it out on the center console in normal height.
  14. #57
    5,175
    Quote Originally Posted by Drevs
    3E does like pictures!
    Speaking of which.
    3E, those pictures you took show the underbody of the car as gray/silver, while your car is black. I'm just curious, are the underbodies on all colors coated with some special gray primer or is that somebody else's car? Mine's gray too but so is my truck, and I never noticed if it was the same gray.
  15. #58
    January 16th, 2007
    ID
    1,657
    Hey goose, I read that in your DIY, but I didn't do it since I always raise to off-road when I'm doing other stuff. Is there a reason we're not supposed to when doing the brakes?
    Noods.
    Speaking of which.
    That is my rig, funny I noticed it too, but I didn't seem to think as much of it to mention it here. Thanks for pointing it out...perhaps someone has an answer.
    '07 RRS
    '03 325i
    '94 GSX
  16. #59
    5,175
    Quote Originally Posted by TripleE
    No harm I think, I used the LR supplied jack and I don't think it would extend far enough in off-road mode, or if it did it would be very extended.
    I would not want to work around/underneath without the suspension locked out.
  17. #60
    July 2nd, 2006
    It's a dry heat
    1,737
    Not really... it's quite straightforward if you're just doing the pads. It was nearly an identical procedure to replacing the brake pads on my bikes, which have, perhaps not coincidentally, British disc brakes.
    How do you lock out the suspension in normal height? Haven't heard that trick before.
  1. Hardly any brakes
    By JeremyD in forum Range Rover Mark II / P38
    Last Post: March 25th, 2010, 10:30 AM
  2. NO brakes!!! Help!!
    By dimitriaudio in forum Range Rover Mark II / P38
    Last Post: January 13th, 2010, 09:59 PM
  3. Brakes?
    By deeveus in forum Range Rover Mark II / P38
    Last Post: August 3rd, 2007, 06:01 PM
  4. New Brakes
    By macattack23 in forum Range Rover Sport / L320
    Last Post: February 24th, 2007, 08:42 PM
  5. brakes
    By laun3310 in forum Range Rover Mark II / P38
    Last Post: November 10th, 2006, 11:52 AM
