Front & Rear Diff Issues + Fluid Changes - Page 9
Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 121 to 132 of 132
Thread: Front & Rear Diff Issues + Fluid Changes
  1. #121
    April 28th, 2013
    Northern Virginia
    2,467
    Re: Front & Rear Diff Issues + Fluid Changes
    Did you have the vent tube cap replaced along with the differential, to prevent the unit from pressurizing and causing seal leaks?
    Dave
    Land Rover Master Tech
  3. #122
    LEGACY VENDOR IMMensaMind's Avatar
    November 6th, 2005
    Wisconsin
    790
    Quote Originally Posted by RoverGuy7 View Post
    This I didn't know about. Would that have been standard practice by the dealership when replacing the differential entirely? Is it something I can easily do myself?
    '06 S/C Overfinch Aero II package, Formerly w/Umnitza Orion Lite UHP LED Halos - now with a totally customized headlight bezel w/Morimoto switchback LED components, ClearBra, Tasmod SS rocker panels; IMMensaMind clear headlight side markers
    Custom '03 350Z Track PPW/Nav w/19" Nismo Z34s.
  4. #123
    September 12th, 2007
    5,175
    Quote Originally Posted by IMMensaMind View Post
    Should be the same as the LR3
    http://www.disco3.co.uk/gallery/thum...hp?album=23952
    '08 RRS HSE Stornoway Gray
  6. #124
    April 28th, 2013
    Northern Virginia
    2,467
    It should be standard practice, however it usually isn't, and yeah, same as LR3.
    Dave
  7. #125
    November 6th, 2005
    Wisconsin
    790
    Thanks for the info, guys - let me make sure I'm crystal clear here. This 'breather cap' is already on my vehicle, but is likely clogged - so I have to cut the tube @ a 45 and install this new Goretex breather element?
    That about right?
  8. #126
    tlt
    tlt is offline
    November 9th, 2013
    Austin, TX
    That's correct....
    PM me for diffs and diff parts information.
  9. #127
    May 30th, 2015
    Mount Dora, Florida
    26
    I am looking into changing my rear diff due to the whining noise as well. My 06 RR SC only has 33k on it but I have taken it into the dealer and had both fluids changed and found the whining noise still is there. He of course gave me a price of 3700.00 to replace the rear diff... LOL... Which is why I will most likely be doing it myself. I have found a couple places online that sell rebuilt ones for 1200.00 but what I don't know is do I have limited slip or not? Any way to look at the diff and tell?
    Also anyone know of a good place to buy rebuilt rear diffs from?
    Mike.
  10. #128
    FORUM MODERATOR
    January 8th, 2006
    Houston, Texas
    4,454
    Check your wheel bearings first...they are more likely to wear out before the diffs.
    PJPR
    13 Orkney Grey RRS HSE Lux
    06 Cairns Blue RRS HSE (200K...sold to a friend)
  11. #129
    5,175
    Quote Originally Posted by mjohnson68 View Post
    Most cars don't--see the very 1st page of this thread.
  12. #130
    Premium Member Frisco_TX_RRS's Avatar
    April 8th, 2007
    Frisco TX
    1,245
    Is there a breather cap/filter for the rear diff too that needs to be replaced?
  13. #131
    November 6th, 2005
    Wisconsin
    790
    I want to reopen this topic.
    I never did get to the Gore-tex filter element when it was last talked about; there were lots of other tire, bearing and suspension fiascos to deal with in the meanwhile.
    The smell of a hot fluid still comes through the vents when the fan is on after a couple of minutes of driving, and persists for about 10 minutes before disappearing. I have yet to track it down, which is why I want to solicit some opinions. Based upon knowing what burning oil smells like, and what coolant smells like, I'd like to eliminate those; I don't think the smell is that.
    I have read that gear oil getting hot/burning smells sulphurish. It's not that. In fact, I located that dif vent, and it appears that the Stealer simply cut off the cap (the top of the tube is just open - I'm assuming for prudence/contamination it probably shouldn't, but it's not an Earth-shattering deal, correct?).
    So what fluids could get hot and send fumes through the HVAC system? It's not linked to use of AC; this happens when the fan draws air into the cabin, regardless of temp setting, and regardless if ECON is lit. I don't know what burning brake fluid smells like, but it seems to me that the only possibilities are brake, refrigerant or transmission fluid (is transfer case fluid a version of tranny fluid?).
    This smell is pungent. It's 'earthy', and fairly acrid. Not rotten egg; not burning oil.
    Anyone have any ideas? Where do the transmission and transfer case vent lines conclude?
  14. #132
    April 5th, 2017
    Dunedin, FL
    13
    I just purchased 3 quarts of mobile 1 75-90 full synthetic for my front transfer unit and rear-end. 06 Range Rover sport hse.
  1. Mobil1 Rear Diff Fluid?
    By brentnclemso in forum Range Rover Sport / L320
    Last Post: December 21st, 2012, 05:57 PM
  2. Replies: 10
    Last Post: March 14th, 2012, 06:07 PM
  3. Front/Rear Diff. + transfer case fluid replacement quote
    By andyboy in forum Range Rover Sport / L320
    Last Post: December 28th, 2011, 12:45 PM
  4. Urgent: Front diff issues - safety related??
    By Norval in forum Range Rover Mark III / L322
    Last Post: April 19th, 2007, 09:25 AM
