ZF transmission oil and filter change.
Results 1 to 6 of 6
Thread: ZF transmission oil and filter change.
    spl
    spl is offline
    May 5th, 2016
    I am in the process of doing a transmission oil and filter change on a Range Rover Sport 2.7 .
    I have an oil recommend as an equivalent which is Liqui Moly ATF 1800.A$22.50 litre.
    I am using a modified steel pan with separate filter so I don't have to jack up engine. Just cut off the filter tube and slide out original sump.
    Also I will change the sleeve plug.
    Banned
    December 5th, 2015
    Brooklyn, New York
    139
    Re: ZF transmission oil and filter change.
    Hi, I am planning on doing the same and have ordered/received the metal pan. Considering that transmission oil change is once in like 50,000-60,000 miles, don't you think it is better to use a original ZF oil? I mean whatever more expensive it can possibly be, given that you get few years of life of it cost difference is pretty much irrelevant, why not use original?
    spl
    spl is offline
    May 5th, 2016
    TOP TEC ATF 1800
    Developed primarily for use in type ZF 6HP XX automatic transmissions, which are installed in various BMW, Jaguar, Land Rover and Porsche models, among others.
    Additionally, Top Tec ATF 1800 also fulfils other specifications – thus further increasing the vehicle coverage significantly. To be used according to the stipulated specifications of the unit or vehicle manufacturers.
    SPECIFICATIONS/APPROVALS:
    Dexron VI ; Mercon LV
    LIQUI MOLY recommends for vehicles with the following specifications:
    BMW 83 22 0 142 516 ; Hyundai SP IV ; Nissan AT-Matic S Fluid ; Toyota WS ; VW G 055 005
    1L Part No: 3687
    20L Part No: 3688
    Banned
    December 5th, 2015
    Brooklyn, New York
    139
    Hi, I see you a have a valid/scientific based answer. Good homework! I mean, I, in my case, just for the life's simplicity, bought an original fluid @$26,72 per can. I guess we all have our own ways
    That metal pan, by the way, looks very well made. I hope it fits just as good as it looks but in any case, craftsmanship looks very good.
    MDJ
    MDJ is offline
    May 17th, 2017
    Any feedback on how the Liqui Moly is performing 12 months down the track?
    Moderator RRToadHall's Avatar
    27,566
    He hasn't been on line in over a year. Quite frankly his posts stick of a corporate or at least commercial person dropping posts in forums.
    ~ Maharishi Mahesh Yogi~
  1. Transmission filter change
    By Tarby25 in forum Range Rover Mark III / L322
    Last Post: June 12th, 2015, 06:48 AM
  2. Transmission filter and fluids change
    By turbostang in forum Range Rover Sport / L320
    Last Post: August 5th, 2013, 01:56 PM
  3. ZF 6HP26 Transmission and Oil filter/fluid change
    By blueRR2006 in forum Range Rover Mark III / L322
    Last Post: March 11th, 2013, 08:17 AM
  4. Started to Change the Transmission Filter
    By cnfowler in forum Range Rover Classic
    Last Post: February 14th, 2010, 04:43 PM
  5. Oil 'n' filter change
    By comports in forum Range Rover Mark II / P38
    Last Post: February 19th, 2007, 02:27 AM
