Front Suspension Clunking ANY UPDATES??
Results 1 to 7 of 7
Thread: Front Suspension Clunking ANY UPDATES??
    rr4
    rr4 is offline
    November 14th, 2005
    10
    I am looking at an 09 RRS.
    Has the clunking issues been resloved?
    Is there anything in the 09 that they have changed that would address it?
    Thanks,
    R
    Guest
    Re: Front Suspension Clunking ANY UPDATES??
    I doubt it....its only on the S/C though
    January 30th, 2006
    McLean, VA
    106
    Yes it is mostly with the SC's .....I had mine solved long time ago......
    06 Range Rover Sport SC/ Givorney Green/Ivory
    Overfinched ECU /pully / Exhaust
    Arden bodystyling
    http://www.postmyimage.com/images/images3ay26886.jpg
    Banned
    November 19th, 2006
    Manchester, NH
    890
    Quote Originally Posted by Range SC
    I had mine in this past week for the " clunking" noises. They replaced the valve block and front sway bar bushings for the system active suspension . So far it's been quiet today running around town.
    June 15th, 2007
    New York City
    177
    I also had the sway bar bushings replaced about a year ago or so. The issue is slowly starting to come back, especially in cold temperatures.
    2013 Range Rover Sport Supercharged
    January 30th, 2006
    McLean, VA
    106
    have them check or replace the bushings and or the lower arm....cuz i had mine replaced at the time where the problem came back the first time,,,,but after replacing the lower arms the problem went away for good......i had the tech. testing it couple of times....I had mine done in Tysons corner , VA dealer over here in virginia
    Arden bodystyling
    June 22nd, 2006
    Long Island, NY
    787
    Quote Originally Posted by eugenek
    Yup same here with my HSE the noise is back and better than ever. Had the bushings replaced and itssssss back. Time to go back to the dealer.
    2006 RRS HSE-Zermatt "Ellie"
  1. Front end clunking
    By eugenek in forum Range Rover Sport / L320
    Last Post: February 22nd, 2017, 05:09 PM
  2. Front-end clunking fixed
    By moodyblue in forum Range Rover Sport / L320
    Last Post: March 7th, 2016, 12:23 PM
  3. hollow clunking in front end? help
    By mullinsford in forum Range Rover Mark III / L322
    Last Post: June 14th, 2010, 07:15 PM
  4. clunking noise after replacing front brake pads
    By DocJoseph in forum Range Rover Mark III / L322
    Last Post: May 12th, 2010, 07:03 PM
  5. clunking from front-end
    By darrinturner in forum Range Rover Mark III / L322
    Last Post: December 28th, 2006, 09:05 AM
