Hardwiring a radar detector - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 51 of 51
Thread: Hardwiring a radar detector
  1. #46
    December 18th, 2010
    Northern NJ
    61
    Re: Hardwiring a radar detector
    bringing back on old thread here but I finally bought my wife a escort redline and hardwired it last week. Had an old escort 8500x50 that I put in for a week before replacing it with the redline. When I hardwired it, the 8500 worked fine turning on and off, but with the redline, I get a low voltage warning and it powers down as soon as the engine is turned off. So when I start the car back up, I have to manually turn the RL back on. anyone else experience a "low Voltage" message? I checked the ground and wire connections, and they are both fine. 2010 sport btw
  3. #47
    August 18th, 2011
    314
    Not sure why you are getting a low voltage issue, but perhaps using a higher rated fuse for the overhead console/lights may be able to fix it.
    '08 RRS SC
  4. #48
    December 18th, 2010
    Northern NJ
    61
    got fed up so i just ran a telephone wire from the detector all the way to the back of the truck to the 12v in the trunk. Coupled it with the smart cord and works great now with a 13v reading. I ran the cord down the drivers side pillar and through the plastic foot guard/carpet near the doors. Can't see the cord at all yay!
  6. #49
    FRESHMAN ROVER freshmaker's Avatar
    May 6th, 2012
    Sparks, NV
    110
    I had a radar detector hard wired to my 2008 RRS the same way and didn't have any issues regarding low voltage. I haven't tried the same on my new RRS but i will try to wire it this week sometime and will report back.
    2011 Range Rover Sport Supercharged [Current]
    2008 Range Rover Sport Supercharged (2012 Facelift) [SOLD]
  7. #50
    May 6th, 2012
    Sparks, NV
    110
    Quote Originally Posted by dkim12 View Post
    Hi dkim12 - I was able to hardwire mine today and didn't have any low voltage problems. Just wanted to report back my experience. I know u already wired it to the power outlet in the boot but if you are thinking of wiring it back to umbertob's way, I'm assuming the connection to the hot wire (white and green) might be the issue. I actually cut the plastic covering on the wire before using the t-taps (14/16gauge) for a better connection. Also check your ground connection as well.
  8. #51
    December 18th, 2010
    Northern NJ
    61
    thank you for the reply! I'll keep it the way for now but I'll try cutting the plastic next time if I decided to redo it yet again. I'm pretty happy with the way it turned out so far. thanks again
  1. Radar Detector Hardwiring
    By cstroh in forum Range Rover Sport / L320
    Last Post: March 28th, 2011, 11:30 PM
  2. help with hardwiring a radar detector (Valentine1)
    By remington in forum Range Rover Mark III / L322
    Last Post: October 6th, 2009, 07:56 AM
  3. Hardwiring Radar
    By PoloJag in forum Range Rover Sport / L320
    Last Post: September 10th, 2006, 07:44 AM
  4. Radar Detector Install
    By brendanwp in forum Range Rover Sport / L320
    Last Post: January 24th, 2006, 10:57 PM
  5. Radar detector installation
    By vesurover in forum Range Rover Sport / L320
    Last Post: October 13th, 2005, 06:25 AM
